Votes
0
Product:
Character Creator 4
Version:
4.3
Status:
Not Reproducible
Issue 10641
Send to iclone 8 from CC4.3 fails
After using Headshot1.0 to add a head to a cc3+ body, the command to send to Iclone seems to work, but Iclone says "failed to load file". I have tried various bodies, all cc3 or cc3+ but nothing seems to work.
I have also tried to save the figure as an iAvatar. But iclone 8 will not import the saved iAvatar. Errors are:
"Failed to load the file"
"Import failed - "
"No standard/humanoid character is picked"
"Import failed - C/users/wayne/appdata/localtemp/vharactercreator4temp/temp/imotionplus"
I had Headshot 2 trial installed, but even after I uninstalled it and restarted the computer, the same thing happens.
Process is
Load character CC3baseplus
Open headshot
Drag png photo into headshot
Select figure with new head
Select file/export/send to iclone/send to iclone
Go to Iclone 8 and see failed to load the file message
OS: Windows 11
  •  4
  •  1939
Submitted bywaynewiz16
COMMENTS (4)
kevindmccoy
Update - I just updated iClone 8 and it is now working for me.
kevindmccoy
I am having the same issue as koshkin24...  CC 4.41.2812.1 purchased yesterday, and iClone 8.4.2505.1 purchased 3/29/2024
koshkin24
Hi!I have the latest versions installed, CC 4.4 and iClone 8.33. However, when I try to export a character created in CC to iClone, I encounter the following problem: iClone failed to load the file 'Failed to load the file'; 'Import failed -' 'No standard/humanoid character is picked' 'Import failed - C:/Users/ASUS/AppData/Local/Temp/ChararacterCreator4Temp/TempAvatarWithMotionPlus.iAvatar.' Please help me resolve this issue.
Feedback Tracker Admin
Hi waynewiz16,
Thanks for your feedback!
Did this issue still happen in CC v4.31?
Also, did your iClone also upgrade to v8.3?
Calvin
Reallusion
