Votes
0
Product:
iClone 8
Version:
8.4
Status:
Active
Issue 11157
Shoulders are behind
Shoulders are always back after export.
I record with Motion Capture (Rokoko) and everything is still fine. As soon as I edit the FBX in Iclone, the shoulders are always bent backwards.
So I adjust them via clavicle and upper arm so that the shoulders are further forward and ok again.
As soon as I save and export them, the shoulders in both files (FBX and rlMotion) are back to their original position as with the import.
OS: Windows 10
  •  3
  •  611
Submitted bymichaelmat85
COMMENTS (3)
michaelmat85
Greetings,
Sorry for the long Dealay, The File I send it to you, was from Rokoko,
The Problem is, when I can't use rlmotion in my Unity Project, so I have to export it in, fbx.
michaelmat85
Yes when I chanche the clavicle it works.
Normally I do it everytime.
Edit Motion Layer -> FK Mode -> CC-Base_R_Clavicle turn it a little bit back, then I turn the CC-Base_R_Upperarm a little bit forward, so the result are nice an smoothly.
But I must change it everytime, and with all the animation it tooks a lot of time :)
Why IC8 do this?, and how I can avoid this.
Video doens't work
Feedback Tracker Admin
Hi michaelmat85,
When I adjust upper arm in Edit Motion Layer panel,then save motion and apply it,it works.So can you tell mek how you adjust clavicle and upper arm?Please capture a screen video about this issue,put it on the YouTube, and add the link in your next comment.Thanks.
Molly
Reallusion
michaelmat85
Hey I added the Rokoko File
Hi michaelmat85,
Can you capture a screen video about this issue,put it on the YouTube, and add the link in your next comment?
Molly
Reallusion
Hi michaelmat85,
I have got it.Thank you.How do you adjust clavicle and upper arm?I adjust in Edit Motion Layer,then save rlmotion.When I apply rlmotion,the shoulder is fine.
Molly
Reallusion
Hi michaelmat85,
Thank you for your feedback.
Can you provide your Rokoko FBX file to help us identify the problem?Please attach the file in your next comment. If the file size is larger than 10MB, you can use cloud services such as Google Drive, Dropbox or OneDrive to make the files available to us and put the link in your comment. You can use Private Comment if you want to keep it private.
Your help is highly appreciated.
Molly
Reallusion
