Votes
0
Product:
iClone 8
Version:
8.63
Status:
Assigned
Issue 12322
iClone’s Final Render does NOT match the Viewport — fundamental software failure
I’m reporting a critical flaw in iClone’s rendering system.
The viewport preview does not match the final render output.
Lighting that looks correct in real-time becomes drastically darker, harsher, or completely different when using “Final Render.” The “Preview Render” option is the only one that matches the viewport, which defeats the purpose of lighting work.
This is NOT user error.
This is the software using two different shading engines and presenting them as if they will match. The result is hours of wasted lighting work because the viewport lies.
For expensive professional software, this is unacceptable.
What I need from Reallusion:
A confirmation that this is a known issue
A fix or patch to unify the viewport and final render engine
Documentation that clearly explains the differences between the render modes
A way to force the viewport shading mode for ALL renders
This problem cost hours of work and nearly caused me to abandon the project.
Other users are experiencing the same issue — please escalate this internally.
OS: Windows 11
  •  3
  •  328
Submitted bymoneypyre
COMMENTS (3)
Feedback Tracker Admin
Hi moneypyre,
There is a workaround, please uncheck the blur or Lens Blur Post Effect,and try it again.
Reallusion
Molly
Hi moneypyre,
We’ve confirmed internally that the issue is caused by Blur + Lens Blur. For now, you can either remove the effect from your project, or try setting the render Anti-Aliasing to Temporal AA and test again.
Soya
Reallusion
Hi moneypyre,
We are very sorry that this issue has affected your work. This is a known issue, and we will fix it as soon as possible.
Here is the relevant information from the iClone Online Manual for your reference:
Render Settings
https://manual.reallusion.com/iClone-8/Content/ENU/8.0/03-Introducing-the-User-Interface/For_Final_Rendering.htm?Highlight=final%20render
https://manual.reallusion.com/iClone-8/Content/ENU/8.0/80-Export/General_Export_Settings.htm?Highlight=final%20render
Preview rendering options
https://manual.reallusion.com/iClone-8/Content/ENU/8.2/03-Introducing-the-User-Interface/Real-Time-Render-Options.htm?Highlight=final%20preview
Soya
Reallusion
